The ipns:// URI scheme names mutable pointers. It is the mutable sibling of the
ipfs:// scheme, and shares its structure, syntax, origin
model, and its deferral of path, query, and fragment handling to the WHATWG URL parser. This
document defines only what is specific to ipns://: what its content root may contain, and how
that root is resolved.
Read ipfs:// first: it defines everything the two
schemes share, including the authority form and why // is required, the origin model, path,
query, and fragment behavior, the ban on endpoint information, and the shape of the IANA
registration. This document does not repeat it.
An ipns:// URI places a mutable content root in the authority and an optional path after it:
ipns://{ipns-name}/{path}?{query}#{fragment}
For example:
ipns://k51qzi5uqu5dlvj2baxnqndepeb86cbk3ng7n3i46uzyxzyqj2xjonzllnv0v8/
ipns://dnslink.example.net/wiki/
ipns://{ipns-name}/{path} maps to the content path /ipns/{ipns-name}/{path}.
Because the target of an IPNS name can be republished to point at different content over time,
an ipns:// URI is a mutable pointer. ipns:// MUST NOT be used as a namespace for a bare
CID that directly names immutable bytes: such a CID belongs under
ipfs://. The only CIDs valid under ipns:// are those that
name a public key, libp2p-key CIDv1s today: a key is a mutable pointer to content, where a bare
content CID is not (see The content root).
ipns:// supports two kinds of content root, and every implementation MUST accept both:
They are told apart by trying the first and falling back to the second: an implementation attempts to parse the authority as a CIDv1, and only if that fails does it treat the authority as a DNSLink domain. Parsing the authority gives the exact steps.
ipns-URI = "ipns://" ipns-authority path-abempty
[ "?" query ] [ "#" fragment ]
ipns-authority = ipns-key / dnslink-name
; (a) IPNS Name: a CIDv1 naming a public key, multibase base36
; (libp2p-key, 0x72, is the codec in use today)
ipns-key = "k" 1*base36char ; canonical form; see "Cryptographic key form"
; for other case-insensitive encodings
; a single DNS label, no "."
; SHOULD NOT exceed 63 characters total
base36char = %x30-39 / %x61-7A ; "0"-"9" / "a"-"z"
; (b) DNSLink name: an ICANN-compatible DNS name, at least one "." on the public internet
dnslink-name = label 1*( "." label )
label = let-dig [ *61( let-dig / "-" ) let-dig ] ; RFC 1123: max 63 characters,
; no leading or trailing "-"
let-dig = %x61-7A / %x30-39 ; lowercase; DNS comparison
; is case-insensitive
As in ipfs://, the ABNF describes the canonical
form only: a base36 key. A key in another case-insensitive multibase does not match ipns-key
but can still appear as input;
Cryptographic key form says how to handle it.
path-abempty, query, and fragment are as in ipfs://.
The same WHATWG-URL-governs tie-breaker applies.
k). base36 is to ipns:// what base32 is to
ipfs://: the canonical
origin string, so producers SHOULD normalize to it
and keep one key in one sandbox for storage and permissions. Wherever the authority also has to
work as a DNS label, an Ed25519 key MUST use base36: its base32 encoding exceeds the
63-character limit below (see Why base36 for Ed25519).ipfs://, a local resolver
or native implementation MAY support a longer name for internal use, for example via a
localhost subdomain; an implementation that cannot SHOULD reject it.base58btc identifier, whether a CIDv0 (Qm...) or a legacy peer-id string
(12D3Koo...), MUST NOT appear in the authority, for the same reason it is unsafe in an
ipfs://
authority: it is lowercased and destroyed when parsed into the authority.libp2p-key (0x72) among them, it accepts, so a new key type can be deployed without revising
this document (see Room for new key types). An implementation SHOULD
document the set it supports, and SHOULD support libp2p-key, the only codec in wide use today.libp2p-key over the same multihash is a
reasonable last resort when nothing else matches..). The dot both reflects public DNS structure and keeps the DNS name
distinct from a single-label cryptographic key.xn--... punycode labels) via
domain to ASCII before it is placed in
the authority; the authority itself carries only LDH labels.Resolution has one step that ipfs:// does not. The content root is mutable, so it MUST first be
resolved to an immutable CID: an IPNS Name through its signed record, a DNSLink name through
DNS, which may itself point at another DNSLink name or at an IPNS Name before it bottoms out.
Everything after that is identical to ipfs://. The CID that comes out is the content root for the
rest of the operation, and its multicodec is what says how to decode the root block and how to walk
{path} out of it, exactly as in
ipfs://. Only the step
that produces the CID differs; the traversal does not.
Otherwise resolution follows ipfs://, with the
IPNS namespace in place of the IPFS one: ipns://{ipns-name}/{path} is retrieved as the content
path /ipns/{ipns-name}/{path}, for example through a Subdomain Gateway request to
https://{ipns-name}.ipns.example.net/{path} when an isolated origin is required.
A DNSLink name cannot appear in a subdomain as-is: its dots would create extra DNS levels and
break wildcard TLS, so the Subdomain Gateway inlines the name into a single label, turning
ipns://dnslink.example.net into https://dnslink-example-net.ipns.example.net. Each . becomes
a -, and any - already in the name is doubled, so ipns://my-site.example.net inlines to
my--site-example-net.
Step 3 of Parsing the authority is what lets that inlined label come back
the other way. The canonical ipns:// URI always uses the original dotted name, never the inlined
label, so an implementation SHOULD normalize an inlined label back to its dotted form before
rendering the URI or deriving its origin.
When the content root is a cryptographic key, a resolver MUST validate the IPNS record's signature as defined by [ipns-record]. When it is a DNS name, DNSLink resolution applies, including its recursion bound (see DNSLink name form).
This section is non-normative.
A single DNS label is capped at 63 characters, and an authority that should double as a
subdomain-gateway label inherits that cap. Because an Ed25519 key is inlined rather than hashed
(see Keys too big to inline), its libp2p-key CIDv1 is 40 bytes, the
largest an IPNS name gets in practice. That is 65 characters in base32, two over the limit, and
63 in base36 (k51...), which just fits. base32 remains fine for the shorter, hashed names, but
base36 is what keeps an Ed25519 IPNS name usable as an authority and as a Subdomain Gateway label.
In practice an IPNS name today is a libp2p-key (0x72), which wraps the public key in a libp2p
protobuf. Post-quantum signature schemes are expected to change that, either as new key types
carried inside that same wrapper, which leaves the authority untouched, or under self-describing
key container codecs that drop the libp2p wrapper altogether. Both directions are tracked in
ipfs/kubo#11281.
The codec rule in Cryptographic key form is written to survive that: it names no fixed set and leaves each implementation to say which codecs it accepts. What does not change is the shape of the authority, a case-insensitive CIDv1 that fits a DNS label. Post-quantum public keys are far too large to inline, so their names will be digests rather than keys, with the consequences described in Keys too big to inline.
An ipns:// address resolves through layers: a DNSLink name points at an IPNS Name or
directly at a CID, and an IPNS Name resolves to a CID. An application that saves an
address, as a bookmark or before pinning, benefits from recording every layer it resolved
through: the DNS name, the IPNS Name behind it, and the CID at save time. Each layer
answers a different question later: the DNS name is the human-readable origin, the
IPNS Name fetches the latest content from the same publisher even if the domain lapses,
and the CID retrieves the exact saved version for as long as anyone keeps it available.
An IPNS Name is a multihash of the serialized public key, so how big that key is decides what the name actually carries.
identity, which stores the key verbatim inside the multihash. The
name is the key, and a resolver can recover it by decoding the authority. Ed25519 is the case
that matters: its serialized form is 36 bytes, inside the 42-byte inlining threshold.sha2-256 instead. The name commits to the key
without carrying it, so the authority is a 32-byte digest no matter how big the key was.The second case produces the shorter name, not the longer one: about 57 characters in base36 against 63 for an inlined Ed25519 key. The 63-character DNS label limit is a constraint on inlined keys, and it does not bite here.
What does bite is that the key cannot be recovered from the name, so a resolver has to obtain it some other way before it can check a signature. Records for such keys carry a serialized copy of the public key alongside the signature, and a resolver MUST confirm that the copy hashes back to the authority before trusting it ([ipns-record]). Because the authority is exactly the hash of those key bytes, the key is itself content-addressed: it can be stored and fetched as immutable data under the same multihash rather than travelling in every record.
ipns is registered as a provisional URI scheme under the procedure of [rfc7595]:
IANA provisional registration for ipns.
That registration is the authoritative record of the scheme name, status, applications, and
change controller; this document does not repeat them. The considerations are as for
ipfs://, with these additions:
ipns:// URI dereferences a mutable pointer, so the
content it names can change between retrievals. Record signature validation and the DNSLink
recursion bound are defined in Resolution and
DNSLink name form.We gratefully acknowledge the following individuals for their valuable contributions, ranging from minor suggestions to major insights, which have shaped and improved this specification.
